- Replies 5
- Views 2.4k
Mopar1973Man 1 post
dripley 1 post
klcammie 1 post
Haggar 1 post
Popular Days
Valve cover, vacuum pump or tappet cover. There is another possible spot is the gear case gasket between the block and the gear case too. You'll have to wash it all down and do short trips and attempt
ltz, Clean the side of the block really well and let it dry. Use flour (yes flour) all over the side of the engine. (you just throw it on there) go for a drive. since the flour is very
Hello guys I thought it was my tappet cover but I replaced and still leaks, is there a common spot for oil to leak causing it to get on VP 44 lined and it runs down the top of tappet cover down back and drips
