- Replies 49
- Views 8.5k
Ihwelk49 17 posts
dripley 10 posts
Mopar1973Man 9 posts
Me78569 3 posts
Sounds like an ECM to me, but I would go through this first. Return the truck back to stock electrically, pull out the edge etc. Get some dielectric grease and clean and apply
Test the alternator for excessive AC noise. The alternator is the first step. You might get away without messing with the ECM. More important to clean the battery terminals. The grounds under the hood
You are not far off from where mine was when the ECM went. Had a boat load of codes except the 606 ECM code. As pricey as they are all of the above is the way to go to be sure. I would start saving up
Truck started acting up last weekend and had codes for APPS. I reset the APPS, which is about a year old Timbo APPS, and ran fine. This evening coming home from work truck was cutting out(dead pedal) Cruise control wouldn't even work and kept kicking off on its own. Got it home thankfully and got codes of 0562, 0575, 0342, 0112, 1488, 0606, 1295, 0237. Have Edge JWA truck is 2001 with 6spd and 273k on clock. Am I lookin and a new ECM? Any suggestions or where to start.
