- Replies 19
- Views 4.5k
Here you go...
I bugs me that the machine supposedly knows but evidently the clerk does not. It does not surprise though.
Did the clerk ask if you wanted fries with that battery test? I like to see 12.4 + volts, below that i feel the battery is on the weak side. 12.2 volts is a low state of charge for a 2 year batte
After a full charge, disconnected, and standing over night at about 55 deg., what should a battery hold it's voltage at? How low is too low?
