Power steering fluid
Ok so on my 99 cummins there is nothing that says what fluid should be in my p/s pump. Can't find my owners manual. So I looked on here at downloads and they don't give a fluid spec. So next thing was google. Some people are using Lucas or atf +4 or whatever. I have a bottle of plain ol valvoline p/s fluid but is that right? Thanks.
  • Replies 17
  • Views 35.4k
  • 2002 and older: MOPAR  MS 5931 or equivalent 2003 and newer: MOPAR ATF +4 type 9602 or equivalent
  • 01cummins4ever
    01cummins4ever
    Nothing but straight off the shelf power steering fluid, Stay away from atf or Hyd. oil.
    I've been using Dextron ATF in my transfer case for years now. No issues to date.
PS for me. Just as available ATF and I have 395k on the oe pump. It must like it.
I don't see a problem with it, it states that it replaces mopar ms 5391, It does not have to be brand specific
I just found it was weird there saying 5931 bottle is saying 5391. Online specs for the bottle is saying 5931 haha crazy.
17 hours ago, 01cummins4ever said:
Yep, probably misprint, I would think 5931 is correct number,
I agree just kinda funny to me by the way. Does anyone know the correct fluid for the transfer case. I've been reading +4 or dexron ll. Thanks
Transfer case: NV231HD, NV241LD, NV241HD, fluid ATF+4 type 9602,  fill to bottom edge of fill plug,
drain and fill plugs tightening torque 30-40ft-lb
Sweetness thank you
Dextron III in my transfer case and Redline PS fluid in the PS pump.  I'm a fan of running synthetic PS fluid because if the heat generated in the hydro-assist system.  Its gets pretty hot during the summer and the fluid capacity is pretty small for all the work that system does.  Just my opinion.....  :thumbup2:
You got a point
