Looking for Staff Members
Got most of my components. Just waiting on the hids. Should be here any day. @Me78569 told me I HAD to run halos though. Think we will ignore him on it this time.
received_1307104862711461_zpswfafc5y6.jp
  • Replies 45
  • Views 8.4k
  • In. Oil is not mine.
  • I put a level on the front crossmember of my truck and jacked the axle to make it level, then you twist the projectors so the beam is perfectly level.
  • what do you know..they are dot cert
so I just send some lights your way to retrofit lol
It's so stupid easy to do.  Literally just put the tail of hte projector through the hole in the housing and tighten the nut on the backside.
10min in the over at 225* for the lenses. Came right apart.
6 hours ago, Silverdodge said:
What's the part numbers and how do they wire
Part number for what? Hid ballast plug into the truck harness and have a separate dual relay as not to introduce noise into the audio system.
Got rid of the bulb cover mount, cleaned out the adhesive, and sanded the chrome so  I can paint the backing a dull color. No reflection.
@Mopar1973Man, kind of funny but the projectors do have DOT engraved onto them. Same with the lenses for the housings. I'll get a pic tonight.
Quote
CERTIFICATIONS: Exceeds DOT requirements
Edited by Me78569
Read the article I created under "how to get better lights for your 2nd gen"
ooooohhhhh purdy
i have 55w hids in already but in cheapo housings...   i still have the stock headlights too so id love to retrofit them
6 hours ago, CUMMINSDIESELPWR said:
ooooohhhhh purdy
I plan on doing a set soon
