Looking for Staff Members
ADR9802V2.7 MPG Release Final
View File
This is the final release for the 2.7 V2 tune.  It includes mpg meter and mpg trip meter.   This flash also includes a better handoff of control between the ecm and the Quadzilla.  Run this with the Quadzilla vehicle profile V2 1998-2002 version 2.5
Edited by Quadzilla Power
Changed the Name of the File (Using revisions system for updates)
  • Replies 77
  • Views 26k
  • Dieselfuture
    Dieselfuture
    I couldn't believe the few small boost leaks I had after i fixed them how much different it was.
  • app-release.apk   There yo ugo.  the beta app has a tune loading screen that helps tell you what is going on.     The difference beyond that is nominal. either will work fine, the
  • this will migrate to the standard version.  The fueling hand off is nicer.  mpg stuff is pretty dang close honestly.   It uses the fueling duration( amount injected) and rpm to calculate instant mpg.
So I downloaded this file on my android tablet and when I go to open it it says “no app can open this attatched file for viewing”. What software needs to be downloaded to get this new update?
***EDIT*** I got it working. Can’t wait to test out the MPG setting and get that calibrated. Should be a really cool and useful feature
Edited by Youngblood24v
So how do I get the mpg setup to work? I have the gauge on my screen but it won’t register any numbers?
3 minutes ago, Mopar1973Man said:
I think you have to select vehicle software 2.7 version, not the 2.5 version.
I have the 2.7 version selected in the vehicle selection tab. How do you use the download to get the update? maybe im doing it something wrong. this is my first time doing a download for the quad. Do i hook up my device or the box itself?
Using a Windows PC download the update. The install the Quadzilla Driver and plug in the USB cord to the Quadzilla and flash the update. There is min-USB plug on the Quadzilla and you flash the Quadzilla using the Windows PC software. Get ahold of @Me78569 he's the Quadzilla king here...
When I plug my quad into the computer it makes a connection noise then a couple seconds later makes the same noise again. Like it keeps on connecting and disconnecting. Also when I got into install the flash the wizard thing won’t pop up when I hook the quad it to install a driver on my computer
Mine does that too. It's a bit buggy. Disable antivirus (seems like a lot of major antivirus programs think the update program is a virus), click update, and then plug it in. It's the only way mine will connect, it sort of "locks in" the connection for me.
The video and directions are pinned to the top fo the Quadzilla section
The beeping is normal.  Thats the quad asking if it should be using the bootloaded or not effectively.  once the flash file connects to the box the beeping goes away.
Like myself I've got all Linux Computers. So I run Virtualbox with Windows installed. Nice part is since the Virtualbox is only used for these things I've got no need for virus software and it been working for quite a while with a problem  My last post about shutter problems at low RPM's was a flash issue. So I'm going to rebuild my Virtualbox and Windows. Funny part is on the Linux side I can ls USB ports and the Quadzilla shows up without drivers. Just I don't have any software to do the flash update.
So when I go to “run as admin” the black box comes up and it starts the countdown. But it says that the driver failed to install? And I can’t connect to my quad to connect to retrieve information. Did I do something wrong? I have windows 7 so I went to step 2 and followed it
Also right after i hit “run as admin” this pops up and I hit accept. Don’t know if it had anything to do with my problem but..C8606AFB-6CBD-4135-B259-9CF0EB29FE36.jpeg.20526f5e3a20cf6aa358b532cca12c5a.jpeg
I’m back at college now so all i got is my laptop with windows 10 so I’m gunna have to try it by going through the windows 10 steps. Maybe that will work if not I’ll try disable the UAC on my home computer next weekend when i go back.
I got the driver to install on my laptop but i still can’t get it to read the info from my quad. I have the right cord because it beeps from connecting but it won’t connect?
plug in the box then click the flash file,  then hit get info from module.
Got it to connect finally, just tried it over and over again and it finally connected. Thanks for the help getting this figured out
Well, I loaded the lastest beta 2.7 flash on the ADR today and updated the iPhone app to the latest beta release 1.9.42 (I think that is what it was) and am testing it. I only got a couple of drives today and have not really had a chance to get a good impression of it yet. I noticed on the data logging that I did that the instant mileage and trip fuel use were not updating with data for some reason, so not sure if this is a bug, or if I need to reset something to make it start working. I will play around with it over the next few days and post updates to this thread.
So far, my first impression, is that it fuels harder and faster than the standard tune I was running before, so I like that. The truck has really snappy throttle response. I will need to be careful not to smoke the clutch, perhaps.
