Adding 2 stroke oil questions
Finally giving into adding 2 stroke oil.
Are there any 2 or 3 or even 5 gallon reservoir/container (with measurements) that gets mounted somewhere and if you put in 30 gallon of fuel, you can open a drain valve on reservoir and gravity feed into tank?
Used to mix 2 stroke oil for outboard motors about 3 times a week.  Gets messy sometimes no matter who well you plan it out.
  • Replies 5
  • Views 2k
  • Most guys here just use a quart bottle with oz. on the side and add depending on the # of gallons they put in.
    That all I use. Pour from my gallon jug into the quart and pour in the amount needed. No funnel needed.
I have a gallon of the walley world tcw3, a measuring cup, a long funnel, paper towels and a box of latex gloves in my bed tool box.  Everything is placed in a plastic bin and no mess.
L8tr
D
