Adding 2 stroke oil questions
- Replies 5
- Views 2.3k
Mopar1973Man 1 post
dripley 1 post
TFaoro 1 post
SilverMoose 1 post
Finally giving into adding 2 stroke oil.
Are there any 2 or 3 or even 5 gallon reservoir/container (with measurements) that gets mounted somewhere and if you put in 30 gallon of fuel, you can open a drain valve on reservoir and gravity feed into tank?
Used to mix 2 stroke oil for outboard motors about 3 times a week. Gets messy sometimes no matter who well you plan it out.
