- Replies 13
- Views 3.1k
dripley 3 posts
CSM 3 posts
Mopar1973Man 2 posts
Me78569 2 posts
Popular Days
Be aware that the blocks and plates set the angle of the rear axle. The angle of the dangle needs to be the same at each end for the U joint to work properly or you will have vibration. If the machi
Smaller blocks and new u bolts.
Tried that on the 5th wheel. The brakes did not squeak bid but my arse made bit of grinding noise. Thanks for the tip.
I have a 2001 dodge ram 3500 2wd. What's the best way to lower the rear?
