- Replies 20
- Views 5.7k
Irondime 10 posts
Me78569 4 posts
Mopar1973Man 3 posts
dripley 1 post
Hello. I got a 2005 5.9 I fried the ecm battery cable arced while it was running. Truck would crank but not start. Don't know what else it may have fried.
So I got a remanufactured ecm. Truck started right up but I had dead pedal. Tried to reset it a few times but still wouldn't work. Procedure I used was unhooking batteries with key on overnight. Key off, connect batteries. Key on but not start. Pedal to floor slowly then back up slowly. Key off.
I've read that is for earlier models, that the 05 with the apps built into the pedal resets every time u key on. I don't know.
So I ordered a new apps pedal assembly thinking I may have fried it also. Can't get it to work either.
Any advice is greatly appreciated.
