TC lockup switch questions.
- Replies 19
- Views 6.6k
notlimah 5 posts
Me78569 4 posts
jlbayes 3 posts
Tractorman 3 posts
Popular Days
I bet you got the wrong wire. There are a couple orange with blacks in the harness bundle. ALL the pcm connectors are the same from 96-02. There are no differences I have ever found and poured over di
*disclaimer* DO NOT RECOMMEND THIS IF YOU HAVE A STOCK INPUT SHAFT.
I tried different setups and I found that a momentary, easy to actuate ,low profile sturdy switch worked the best. It took me awhile to find my final switch, but I did find one on Amazon. The switch
So I installed a tc lockup switch last night, and I'm not sure where I went wrong. I followed the tst website link but it doesn't seem to work.
My truck junction box looks a little different than the one in his schematic but I'm pretty sure I did it right.
Here is what the truck is doing. First, with overdrive off, I'll get the truck to second gear, and flip the switch on, and nothing different happens. It'll shift up to next gear as I increase speed. Then I can come to a full stop and the truck doesn't want to stall or anything. Or I can be cruising at 35, and punch it and he truck will downshift. The only thing that seems to be different is if switch is off, and I get on the freeway and up to speed, and then flip it on, it seems to be locked. I can floor it and it won't downshift. But if I come to a stop like getting off the freeway, and I leave switch on, it still acts like switch is off. Like I can come to a full stop and it won't stall or anything. Then I can accelerate as normal.
Was I supposed to ground out my switch to a ground wire or something? I found the orange and black wire at the ecm (my ecm connectors look slightly different as well. I have female end that plugs into male pins on the ecm) and followed it into the main harness along the firewall to the driver side where it comes out of the main harness. I tapped it there with one of those splitter snap connectors. Ran that through the firewall and to my switch and connected that end to the "on" terminal of my 2 post switch. The ground/off post I just grounded the to the metal structure behind instrument cluster. As for the junction box, I just pulled the trans relay, and jumped the two parallel posts, not the 3 post side.
Where did I go wrong? Thanks
Edited by Florin1
