Fuel Pressure Gauge needs a Light.
Any one know a simple place to hook up the gauge light. I mounted it down near the floor in front of the 4wd shift lever for protection from feets. It is a good spot cause I can see it without looking thru the steering wheel etc.
Been working so hard lately, not much rest, I need simple if you know a spot down there.
  • Replies 12
  • Views 2.7k
    There is the ash tray light. You could easily tap that wire and pull light power from there.
  • I'd also go with Mikes suggestion since it's so close to where it's mounted.
  • Thanks you two... I like it down there. Inexpensive and I like Isspro gauges.
Thanks you two... I like it down there. Inexpensive and I like Isspro gauges.:thumb1:
i did the same and swapped in a LED bulb, most important gauge needs to be the brightest!
I got it hooked up. Now for some night driving with confidence
I like the idea the brightest is the most important :thumb1:
 I don't know if they work with Isspro, haven't tried it yet Matt. Don't know if you just change the bulb or if you need to wire in a new bulb socket.
Oh well... I just got a basic black trim f/p gauge. That green light would be nice though That's how they are on the Pillar gauges on my 02 and it's very nice.
Well you can still get the green lense cover for the regular bulbs @JAG1. That's what I have on my a pillar gauges now.
socket wedge 194, ebay or amazon for a couple bucks for 4
