- Replies 28
- Views 4.9k
Timburrr 8 posts
Mopar1973Man 5 posts
TFaoro 4 posts
Dieselfuture 3 posts
Popular Days
YES - it should be perfectly dry inside there. Time for a rebuild! If you've got large and small snap ring pliers they are super easy to rebuild. A genuine rebuild kit is $60 or so from DAP.
@Timburrr I rebuild a turbo in the past on a different vehicle, they are not hard like mentioned. And I believe the only difference between hx35 and hx35w is one has a wastegate the other one doesn't
So I'm installing a new exhaust manifold (you'd be surprised how many issues you can run into doing this simple job) and this is what I find. Is this enough oil for me to be concerned?
