iQuad freezing with custom tunes
So after talking with customer support and getting my Adrenaline updated to V2 on the 4k box I decided to start building a tune. I started with Nicks DD tune and a started my test drive. Only made it a couple hundred yards and iQuad froze, to the point it locked up my tablet. I dont want to call Zilla back and waste their time since there is a plethora of knowledge here. is there an update for the app I need or is it a tune related error?
  • Replies 76
  • Views 18k
  • Quadzilla Power
    Quadzilla Power
    I've done some more testing loading custom tunes and are working on getting the app updated with some better user experience.  First, loading a V2 tune on a box that isn't a V2 box can take up to
  • Dieselfuture
    Dieselfuture
    You can send it in if you don't mind waiting, or you can do it yourself if you have windows 7, anything other then windows 7 gets to be tricky but @Me78569 has a wright up on it here  After some
  • Quadzilla Power
    Quadzilla Power
    I will upload the right version here in a moment. Sorry about that. I didn't think I needed to update here because the Play store had the latest version. But thinking about it. I should for consistenc
Well seems like out of nowhere my app is freezing up now when I try to go to custom turning, it will go anywhere else like setting, vehicle selection etc but as soon as I try to access custom tuning it says unfortunately bla bla bla, so I tried my other phone and it's fine, linked unlinked unplugged the box from under hood restarted the phone etc same thing the phone that was always with the truck can't access custom tuning but my other one does it just fine.
I must add it all started when this morning I tried changing a variable in my daily tune and went to save that's when it did it and it's refusing to go back to custom tunes and just hangs up and once I hit ok to unfortunately... it just loads up again so everything works but still won't let me access tunes. :popcorn:
Try uninstalling the app and reinstalling. It might straighten out the corrupt data you've got.
I was afraid you'd say that, can't remember does that erase all tunes too
Just tried loading app again from download section and it still has that big gear icon to access settings, I believe it needs to be updated. @Mopar1973Man
I tried it here and got big gear then went to quad site and it was normal sizes. It could be my phone being goofy.
Sorry correction, I went to play store and it's working right, even high idle is smother.
I will upload the right version here in a moment. Sorry about that. I didn't think I needed to update here because the Play store had the latest version. But thinking about it. I should for consistency's sake.
Should be updated now. Because of some weirdness with the numbering system it is actually 1.9.41(61) instead of build (59) which was up here previously. I don't understand the numbering either.
