- Replies 27
- Views 6.2k
notlimah 10 posts
trreed 7 posts
jlbayes 4 posts
Dieselfuture 2 posts
I have the Mangaflow muffler. Not sure of the length but it's a straight through design. Disclaimer: if your wife gets mad about this, it's not out fault.
That'll be very tight if you can make it fit. That tire of yours is 32.71" diameter. I currently have the stock 265/75/16 spare and the 4" exhaust is about 3/4" away from it. That tire is 31.65
Uhhh, I'm not the takin the blame that's for sure!!
Well, was crawling around under the truck installing my Timbren's noticed two holes in the exhaust. Maybe a BB size hole in a couple of the welded seams. Is this something I should change out sooner then later? Or would I be good waiting until I get around to it?
