Holes in exhaust
Well, was crawling around under the truck installing my Timbren's noticed two holes in the exhaust. Maybe a BB size hole in a couple of the welded seams. Is this something I should change out sooner then later? Or would I be good waiting until I get around to it?
  • Replies 27
  • Views 6.1k
  • I have the Mangaflow muffler.  Not sure of the length but it's a straight through design. Disclaimer: if your wife gets mad about this, it's not out fault.
  • That'll be very tight if you can make it fit.  That tire of yours is 32.71" diameter. I currently have the stock 265/75/16 spare and the 4" exhaust is about 3/4" away from it.  That tire is 31.65
  • Uhhh, I'm not the takin the blame that's for sure!!
5" and muffler should be perfect.  My truck with the 4" and the muffler is very, very quiet in the cab.  Not outside though!
What muffler do you use? I'm thinking that's what I'd go with too. 5in with maybe a 51' Donaldson.
Disclaimer: if your wife gets mad about this, it's not out fault. :)
Says the guy with no 5" experience. They can still drone horribly with a muffler.
I had 1995 with 5" exhaust that was so bad with drone right at 65 MPH that you needed ear plugs to be on the highway. You could not speak or talk to a passenger till you dropped down to about 53 MPH. So I ditched the exhaust and put in a Diamond Eye 4" with flow through muffler now it's just as quiet as my truck with 3".
On 7/13/2017 at 6:13 PM, notlimah said:
Were these straight piped?
12v has a muffler.  24v did not.
