Towing with xzt
So just wondering if anyone's heard of any problems towing with the xzt on level 3? Reading through some of the manuals for the edge ez and it recommends NEVER towing on level 3 and with these two boxes being quite similar it got me wondering. Not sure if that's just a legal/responsibility thing that they use to cover themselves when people try turning up the power and towing and causing damage to their trucks or what, but just wanted to see what you guys thought.
  • Replies 12
  • Views 4.6k
    Edge Comp states do not tow on level 5. I towed on level 5x5 for over 10 years never caused any problems. Best fuel mileage was always on the highest setting.
If your trans can handle it tow on lvl 3.  I am sure yours can.
it should be fine for timing. The OEM timing curve is VERY safe under high load situtations.
Cool well I'm just gonna run it at level 3 and see how it goes. I'm sure it'll be fine, just wanted to check.
In case anyone was wondering my truck/trans did fine towing on level 3. The little extra power combined with the new trans made towing sooooo much nicer then before, even towing a smaller trailer.
Edited by notlimah
Looks good!  do you like the 4th gen style mirrors?  I'm thinking of getting a set but I'm still on the fence yet.
I love em! Don't think I could drive the truck without them. The main glass is huge and the convex mirrors on the outside are so nice to have when backing up.
Your not setup very well in that picture. Trailer tongue is high. Nose pointing upwards and swatting... :poke:
My main concern is my ability to transition from the little corner blind spot mirror to an independent, full length convex mirror... but I do need a replacement set, so what the hell lol
Yea yea I know! Still had a tiny squat. Although it's exaggerated in this pic, measuring wheel wells they were exactly level. I would've lowered the trailer on the hitch but I was borrowing it and the owner preferred me to not move it since it was setup for him. Figured it wasn't that far off and I wasn't driving far so I didn't argue.
I went from the stock non-tow mirrors to this so huge adjustment. Took a couple drives to get fully used to the view angled and what not and then it was no looking back. Backing up now I only use the convex mirror as I can see all the way down the side of th truck, rear tire and the lines I'm backing into.
That's the main reason I want them.  Good to know about the visibility!
Forgot to mention, trans temps were around 130-150* the entire time on the freeway. In town it'd get up to around 160* but not much over. Only time I saw over 190 was after attempting to back up into a spot I know I couldn't make but the guy parking me thought I could. :doh:
