Quadzilla Shudder light throttle
Here is what is happening for my truck. Any power level above ZERO and any tune including DEFAULT tune will do this. ZERO level is clean and smooth no issues. Reflashed my Quadzilla with the current tune and even dumped my iQuad App and reinstalled.
  • Replies 335
  • Views 51.3k
  • Alright anyone running the v2 stuff that wants to mess with the new stuff you can run this flash.   The idle to fueling handoff is signficantly smoother.      This has the gallon t
  • bite me guys, bite me
    Pretty sure ill check.
At what rpm and load is the miss not there regardless of temp?
Now since my exhaust rotten off the muffler. I now shorten it up to the good stuff left and put a turn down on it. You can really hear the miss now there is no muffler and open pipe under the cab. Again any Quadzilla setting above ZERO will produce the miss. Zero is smooth and clean. I know I've got to get a video of it but I'm trying to find my tripod for my camera. Hard to hold the camera and my phone at the same time attempting to record as I hold the throttle (about 2% TPS 900 RPM) and change levels up and down.
https://youtu.be/4Tq1gQewzpE
If you pull away from a stop light at %20 throttle would this happen?
Does this happen if you idle around a parking lot not using the throttle input?
Most noticeable rolling in parking lots where speed and throttle are low. Like rolling in my driveway sounds sick with a nasty miss as I roll in the yard on light throttle. All I got to do is switch to level ZERO it's gone smooth as silk every time. If I let off the throttle it disappears. Throttle harder it disappears. Another spot is in small towns where speed limits are as low as 15 to 25 MPH shows its ugly head and sounds nasty.
so idling around a parking lot with no throttle input has no issues?
Yeah and no. If the ECM applies power from the anti-stall feature then it could possibly create that issue as well. As long as it hits that throttle amount then YES it will stutter and miss. If the Quadzilla is on level ZERO no issues.
53 minutes ago, Dieselfuture said:
Can it be apps in any way, maybe level 0 doesn't use it
Nope. Because if I completely unplug the Quadzilla there is no problem hence how I found this issue in the first place.
My guess is,
That when the truck is at low rpms and hte "anti stall" function is going on that the ecm is actually sending out priority 3 messages rather than priority 1, ( higher being more important) and the quads messages are getting in the way.  Once the ecm has deamed the truck as  "good" then it stops sending priority 3 and goes back to priority 1 and the issue goes away.
Mike,
What RPM does the issue go away, If you are low throttle through a parking lot and increase rpm's when does it stop?  1000 rpm? 1100 rpm?
Alright @Mopar1973Man and @kzimmer Try this flash.  I have upped the lower limit for rpm for quad take over to above 1000 rpm.  This should ensure that "idle state / anti stall " is not confliscting with the Quad.  This is a guess though.
ADRV2easytime.exe
All you did with that flash is move the starting point of the problem to 1,000 RPM then it starts it misfire after 1,000 RPM up to 1,200 or so. So this still points out the low end of the Quadzilla is doing something to skip or misfire cylinders. Again set for level 0 no issue.
Random. All you've  done was moved it to 1,000 RPM starting point. Below 1,000 runs smooth and normal. Still in all turn it level zero or just unplug the Quadzilla problem gone.
have you tried any of the old adr tunes, pre v2?
1 hour ago, Me78569 said:
@kzimmer  Can you let me know if your trucks issue is fixed?
@Mopar1973Man is it the same cylinder or is it random?
Here's my post in the other thread for reference:
Hey guys,
I am having a small issue with the newest v2 standard fuel update. If I am stopped, in neutral (or park, it's an auto), and give it 2-4% throttle and hold it there, the truck lopes badly. It'll also do this in drive with around 4-6% throttle. It makes parking lot cruising tough. Very repeatable, does it every time.
I'm the same as Mike. Moved the RPM and TPS of the problem up. 2-3% throttle before, now 3-4% throttle. Cleaned up by 1000rpm before, now cleans up by 1030.
Side note: Aside from this small issue, I am loving how this tune runs. I also really liked the smoothing factors you added. I hope those get put back in when this is resolved.
shoot me now. :doh:
lol I took it out and people said " hey that's better" lololol ugh
alright @Mopar1973Man and @kzimmer
Does this happen when in warmup mode?  IE when the bar is green on the iquad app.
I forced warmup mode on by setting it to 180. I was running at 165. I would say it was 95% gone. Like I had to really try to listen and feel for a lope, and the 5% that I thought was left may have just been my imagination.
It ia fair to say that this only happens when boost = 0?
Alight try this one.  Another change I made before the issue happened was change the map sensor offset from 12 psi to 13 psi to keep the quad from reading hte wrong boost value.
This tune makes it impossible for the quad to see less than 0 psi of boost.
ADRV2easytime.exe
No. As long as it's in warm up mode no issue smooth running. As soon as it flips over to red bar and Quadzilla it start to miss at that low throttle.
ADRV2easytime.exe
Definitely when boost shows 0 for me. Tried this one. Still does it. 2-4% TPS, 930-980 rpm.
