Need 32 stock lugnuts for dually
     At Les Schwab to buy a set of M-55's and switch from the old and corroded aftermarket aluminum dully wheels to stock steel and found out that my lugnuts will not work with the stock wheel and that i need to buy a set of 32 lugnuts at $11 bucks a piece. Can any one help? On a side note i am thinking of putting a second fuel tank in place of the spare tire. direct me to a old thread or chime in. My idea is to have the second tank feed into the stock one, so when the stock tank gets dry flip a switch and refill it with the second tank.
  • Replies 9
  • Views 2.3k
  • Plain stock ones I see on Rock Auto are less than 100 bucks, $2.69 each + shipping. Rybestos http://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,whee
whats the reasoning for the 2nd tank?
Have you checked rockauto for lug nuts?
     Ya Rock Auto is $218.88 for 32 of them. I could understand ARP stud kit but these are just plain stock lugnuts. 2nd tank just because I can. Extra range and stuff. Ran out of fuel in Nevada with a Ford Explore that got 13mpg and only had a 12gal tank. NOT FUN!!
I went back to stock rims on my 01. Drove around to 3 tire shops and found 32 used dodge second gen lug nuts for 20 bucks. Had to look thru a bin of them but barely found the 32 I needed.
http://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,wheel,lug+nut,7676
The Dorman were half that much.
Edited by dripley
56 minutes ago, Royal Squire said:
Dually nuts are likely higher
Yep. went back looked those up and sure enough 218 and change.
I looked on e-bay and did not see that one.  Thanks for finding that. I'll buy that and be done. thank you  for you help.
I bought a few stock ones for my dually at Oreilly's but don't remember the price. Didn't seem like it was too bad.
