Dodge Dana 60 high steer
- Replies 13
- Views 5.9k
Scottfunk 5 posts
Dieselfuture 2 posts
WiscoRedkneck 2 posts
jlbayes 2 posts
The 00-02 ball joint angles is typically why. I have yet to see anyone offer anything for this axle.
Ok first off I get that NONE of you have a need for high steer arms with your fancy track bar and all. But I used a Dodge Dana 60 front in my Cummins swap project and unfortunately with the lift I ended up with, my drag link is ridiculously steep and the bump steer is totally undriveable. My question for you Dodge guys is do you think there is enough meat in the steering knuckle to drill and tap 4 holes for mounting a high steer arm? I know they make high steer arms for the ball joint 60's used in the Ford Super Duty but for obvious reasons no one makes one for the Dodge axles. I attached a picture in case anyone would like to have a look while they ponder. The white dots are where I think would be the most appropriate locations for holes.
.![imageproxy.php?img=&key=4d11e5b7ded08803]()
Edited by Scottfunk
