- Replies 14
- Views 4.6k
Mopar1973Man 7 posts
Dieselfuture 2 posts
jathanmentzer 2 posts
harg432@msn.com 1 post
No matter what that transmission is coming out and being fully inspected for damage and clean all the debris out of it. Get enough junk in the oil holes for the bearing either will plug the oil holes
Complete disassembled main shaft nut loose-- washer hitting 5th gear syncro fork (aluminum) replaced nut -shift fork- 5th gear on main shaft
I have aluminum flakes in my NV4500 oil looks like metallic paint What can be wrong? What is aluminum in the transmission?
