Turbo Upgrade HELP
Ok guys I am having to replace my head gasket and while I’m at it I decided to put in a new turbo..... after a ton of searching I am no further along in my quest to find the turbo I want. With all the sales going on next week I’d like to take advantage of it!!!
-I would like 500 ish horse power
-this is my daily driver
-I tow a 10,000lb horse trailer once every other month
-I’m running a FASS 150
-ARP Head Studs
-HX40 down pipe
-Quadzilla V2 tuning
I’d like to pick the right turbo so I don’t regret my decision down the rd. I am torn between a few turbo sizes...
-S364/68/.70SXE
-S362/65/.70SXE
-S300g (57/60/12)
If you guys guys had the opportunity to start fresh with a new turbo what would you purchase?
Hopefully you guys can help me reach a decision!!
  • Replies 37
  • Views 10.2k
  • Think of the turbine as a lever. The longer (larger diameter turbine wheel) the lever the more leverage you have on what you are trying to move.
    I'm kind of the same way I hate to spend large amount of money on parts I'm not certain of. I tend to come here and lean on the guys for assistance and helping me pick the right stuff. The neat part i
  • I've run both of those turbos.  I have slightly larger injectors than you do (by a whole half of a thou!).  Currently running the 62/68/12, and with the v2 tuning, spooling after a shift is no problem
12 hours ago, Mopar1973Man said:
I'm kind of the same way I hate to spend large amount of money on parts I'm not certain of. I tend to come here and lean on the guys for assistance and helping me pick the right stuff. The neat part is we all learn for each other experiences and know what works and what doesn't work.
Lol wish i was smart enough to ask the experts before i made my purchases 2 twin kits and 3 sets of injectors later.... lesson learned!
6 very different turbo combinations, 3 injector sizes and 4 pumps later. LOL
  • 4 weeks later...
Ok guys I was trying to install my new turbo and I found this rather interesting. The stock turbo has threaded studs into the turbo flange. The exhaust housing has the other two threaded bolts. Is this normal? I was told usually the exhaust manifold has 4 studs on it...:think:
Yes, that is normal.  You're gonna have to get two M10x1.5 bolts for the non-threaded holes on the manifold.
I’ll upload pics as soon as I get home
Mine was 2 of 1 and 2 of the other. I think that is standard for the HX anyway.
On a 24v you should have two in the manifold and two in the turbo.
Ok guys next issue has come up. My new 90* for the S362 is different than my stock one. It’s a shorter bend and a shorter part in overall length.  I cannot use the stock 90 because it twists the turbo (larger compressor housing) so the oil drain is passed 20°s to the side and not level to the world.  Second problem is that they are two different diameters. See pictures attached.
Option on one I get a coupler that necks down and is a little longer so I can make the connection. But who sell that sort of thing?
Option two I find a different 90* that is a larger diameter and an inch longer but it still has to maintain that sharp 90*.
I have no idea how to solve my problem but I am slowly beating this truck into submission. Persistence is gonna pay off!!!!:burnout::USflag:
The od still looks like it is close to 3" is it not?
The new one has a 2.75” OD. The part is also too short to connect to my correct intercooler plumbing
@jlbayes
Ok guys. Started the truck did the valve adjustments. Checked for leaks all is well. Took the truck for a spin let it get warm. Now ima let it sit overnight and tighten the head studs. Any break in period for the turbos? Or the gasket? I plan on tightening the studs next weekend or so.
Studs, one at a time completely remove the nut and washer. Relube the stud fine threads, both sides of the washer and the nut. Pull right to arps spec. Make sure the stud is not bottomed out in the block.
Where did the turbo come from? Very odd it came with the smaller discharge. The elbow being shorter I get but not the smaller diameter. Is not a drop in at that point.
I’ll take care of the studs as you said above this afternoon when I get home!! Thank you @jlbayes
Power Driven Diesel was one of the only vendors that I could get to ship to ca. The 90* that came in the kit does don’t fit what so ever... However I found out my stock 90* elbow could work I just had to adjust the Turbo compressor housing a lil. Had no idea I could even do that:whistle2:
@jlbayes how many re-torques can the ARP’s take? I’ve always wondered that. I work in structural steel and they only allow the use of high strength bolts once if it needs to be removed it’s tossed. Granted they are not as much as ARP’s
Edited by JDHudsn
I should say disappointed. I more or less was frustrated with every bump in the rd. With the instillation of the new head and the new turbo. I was burnt out on the project. The turbo is great. Power Driven Diesel has great customer service and great people to deal with to be honest. @Silverdodge
I do three on a fresh gasket after the first torque and start up.
