- Replies 58
- Views 9.4k
Red Rambler 20 posts
GSP7 18 posts
Mopar1973Man 13 posts
Dieselfuture 4 posts
Aliens have landed
I wouldn't make a run all the way to the front again for just battery power being there is a 10 AWG line already back there for the trailer power. It's got a 40 AMP fuse already too. So my reverse lig
Just in case, when I put my air compressor in and extra lights for backing up or just to see behind me if I'm in the woods, I ran a piece of pex inside driver side frame as conduit and shoved whatever
I am adding a 20" light bar to my 01. I will be making a bracket to add it under my rear hitch, somewhat hidden as much as possible as it is a slim lightbar. Can I run the harness to my non main battery without ill effects? I will be running an inline fuse as well as a relay. My goal is to flip the switch on while backing up to increase my visibility while backing as my reverse lights are not bright at all. Would it work best running from my main battery?
