- Replies 26
- Views 4.5k
Thatguy 8 posts
GSP7 7 posts
Mopar1973Man 4 posts
wh82 4 posts
Popular Days
its definitely came a long ways. I think i'll start visiting here more often compared to the others. Better informative information here
Alternator Starter and Parts wholesale. I called to order,there out of florida. The guy even sounded like an American! dam I didn't even know you had a store mike,well my 2wd is reading a little
So I get the low battery light otw home, barely make it home with my edge reading 9v. I pull the 2 pin plug on the back of the alternator to check to see if the computer is calling for the alternator to charge. On the hot wire I got 9v,the ground wire I get 40 ohms . Isn't 40 ohms to high for the ground? I figured it should read a lot lower, didn't know if that was why my alternator isn't charging or not.
