- Replies 18
- Views 5.2k
Popular Days
216 and white smoke means the vp44 is likely done. the timing piston has likely gotten galled up and is getting stuck when it is cold. once you get heat into it the metal expands and the timing pist
The crank sensor and map are on the same 5v reference......
This little detail should be a huge red flag for everyone. Just sayin.
I have a 2002 24v and i have recently intsalled a Quadzilla and now have serious problems. Truck ran fine before i installed it and now it I have 3 codes p0236 p1690 and p0216. Exhaust is always a constant white smoke when motor is warm or cold and have excessive blow by and oil. When its cold it has a dead pedal then when it gets warm after 30min of driving the boost on the iquad app is always reading 48 pounds of boost then it runs alot better but have to have the power level ag atleast set to 4 for no dead pedal. like i said before i installed the quad it never had any problems.
