- Replies 18
- Views 8.2k
Mopar1973Man 7 posts
Dieselfuture 2 posts
Dmaney 2 posts
abner99 1 post
Good info ..... thanks Mike!
No, synchromesh only, unless you want to try and repot back with results I've read of few people running something other than synchromesh but never heard the end results, probably sold the truck
What I've been told by my rebuilder "Yes." Now as for most here will say used PenzOil Synromesh oil. Basically PenzOil technically is a GL-4 fluid but it's too thin to make the rating.
This was a very heated and debated topic which I'm will to bring back up and report. I'm at 68k miles on the fluid. I've ran for 2 or 3 winters now and have zero issues shifting. Fluid operated greatly in temperature to -35*F and zero issues. I just checked the fluid level and color and it still like it was poured in from the bucket. Clear amber color and discoloring yet. By early summer I'll have 100k miles on this fluid and will check again on the color I might push past the 100k mark if the color is still bright and clear.
Now that I'm travelling 250 miles every Tuesday, Thursday, and Saturday hauling @MoparMom to Dialysis treatments in Ontario, OR I've had to drive in everything from subzero winter driving to scoring hot stuck in traffic. Eve3n toss in trailer hauling once in awhile when we decide to cheat and haul the RV down and camp out near the clinic so to cut down on the traveling.
I can say without a doubt that Mobil 50 SAE transmission fluid is a SAFE fluid to use in an NV4500 transmission. It will not harm the syncros nor have any impact on the shift quality. I'll re-update this thread again when I cross the 100k mark. Currently I'm about to cross 329k miles on my next trip down. Figure 250 per day, 750 per week and 3,000 per month bare minimum mileage. This typically is higher because of other travels through out the days and weeks. Still I've not had a single issue with the transmission fluid or any poor shift qualities.
