I have a 2001 4x4 with a six speed transmission and 200000 miles.  The truck is a one owner,  I bought it from my Father in law and is completely stock.  I have been around the truck since it was bought new.
The truck was really strong until around 190000 miles when the VP44 went out.  The pump has been replaced with a unit from a local re builder in Memphis TN.  Since the VP44 replacement the truck has not been the same.  I drove it around 200 miles yesterday and it averaged 11MPG.  I have owned 24 valve Dodge trucks in the past and have always gotten high teens on fuel mileage and had much more power.
When I am accelerating thru the gears I cant manage more than 5 pounds of boost until the truck gets up to 2100 rpm and it is like you flip a switch and the boost raises quickly to around 22 pounds.  If I am cruising on the freeway around 70 MPH I have around 10 pounds of boost and the exhaust temp is around 900 degrees.  I am unable to produce more than 5 pounds of boost under 1800 RPM.
The truck has never had any injector work done that I know of. The engine runs and starts perfect it just does not have any power.  I cleared all the codes from the computer with a Matco scanner and drove the truck.  I had a P0216 code re appear but I don't have any of the symptoms related to the VP44 going out unless the low power and fuel mileage are related as the engine runs perfect.
 Any advice on where I should start looking to find my problem?  Don't know if it has any bearing but I cant make the truck produce any black smoke.  I know black smoke is not necessarily a good thing but all of my other trucks in the past have had black smoke.
I have made some up grades to the truck since I have been reading on this forum,
Gauges,  Fuel Pressure,  Boost Pressure and Exhaust Gas Temp.
Fuel Pump,  Fass 95 GPH.  I have 17 pounds of pressure while driving it down the road.  The stock pump showed to have around 11 pounds at an idle and 7 pounds under wide open throttle.
I am not looking for a power monster only to get back to where the truck was before the VP44 replacement.
  • Replies 58
  • Views 11.1k
  • Dieselfuture
    Dieselfuture
    I could be wrong but, it sounds like you might have something going on with your 5-volt Loop, oil pressure sensor is on that Loop if it's shorts out internally it will create these similar problems. J
    I would keep your pair of ECM and PCM. If the other donor truck is a matching truck with same options then I would take the ECM and PCM for spares.
    You could just unplug it for a test drive. The gauge will not work but it'll prove the short idea.
It might work for the test to verify but not a replacement. So it worth it for the testing aspect but create its own issues. Like I've found mismatched PCM vs ECM will cause communication problems as well. For what we want it for and testing the APPS sensor just plugging in the donor PCM and turn the key on and cycling the throttle up and own with your scan tool will tell us if its the problem.
I have learned a lesson on this adventure.  Mechanical problems are much more enjoyable to work on.   Wiring issues are really a pain.  I have used a Fluke Meter more in the past two days than in my entire life.
I have been having some similar issues with power/boost/milage... Lots of good information here!
One thing that I was not aware of is that the ECM and PCM must be matched to the options in the truck... As I am just about a day or two from beginning to tear down the truck I wrecked, to pull out modified motor/trans, and replace stock drive train in the newer (to me, both 1999s) truck... I am wondering if I should swap ECM & PCM as well? Would I need to use my old instrument cluster as well? I think they are linked.
Sorry if I'm side tracking this thread a little. I am just trying to get a big picture game plan together, and organize this potential fiasco as best I can.
I called auto computer spectlist.  They said the PCM had no bearing on the APPS voltage being erratic.  It was the ECU that controlled the APPS
Im confused as to is the issue in the PCM or the ECM.
I know PCM has something to do with the APPS due to unpluging the PCM corrects my erratic APPS.
Which should i be looking to replace PCM or ECU?
Automatic or manual?
If you are manual like me then the PCM does control the APPS sensor line because there is no vacuum cruise motor like the automatics use. So my PCM is directly connected to the ECM sharing the APPS sensor wires. Where automatics still share it but only for sense of how much TPS signal for shift signal. If you unplugged the PCM and the signal is now stable it still lean back on the fact the PCM is screwing up the signal.
Look at C1 pin 22 that is APPS sensor signal.
Now look here at Pin 28... Yes, they are connected and share the signal.
It is a 6 speed truck not auto.  Im at the point i will replace both if needed.
I will call them back and specify i have a 6 speed truck.
Thanks for the reply.
Year makes a difference also. I was thinking 01 and 02 manuals have the fly by wire cruise. Not for sure on the years fhough.
What options should I pay attention to? So far, the only difference I see is the donor truck has posi rear axle, and the new truck doesn't... Also little things like my doors don't auto lock at 10mph, and the O/D on-off button on the end of the shifter doesn't do anything. No light on the dash either. Even when I first turn the key to the on position... Other than that, everything is the same, as far as I can tell... Someone deleted badges on new truck. Old truck was an SLT.
1 minute ago, Mopar1973Man said:
Electrical options. Anything different between the PCM options and ECM options.
I have no idea what options those would be...
Like I said... The only thing I see that is different is the O/D on-off button... It's not marked on the shifter, and it does nothing when I push the button... The donor trucks is marked, and it down shifts to 3rd when you push it, and the dash has a O/D off light ... Ever heard of an auto truck not having the O/D off option?
Like for example.
  • Manual or Automatic transmission
  • HO or SO engine
  • Highline central timer with security feature
This are just some of the things that can make trading PCM and ECM hard at times.
Got new PCM in today.  Cleaned ground and installed the new PCM.  I still have no change in the truck.  No power above about 1/8 peddle.
I do not have the scanner to plug into the truck at this time,  it belongs to my nephew and he has to use at his shop during the week.  It will be this weekend before I can get it back.
I have new codes with the new PCM by key display.
P0122
P1698
P0522
P0123
P1295
Still chasing the problem.
P0122
P1698
P0522
P0123
P1295
Completed APPS voltage to high test.  At the end I got to replace ECM.  I was allowed to borrow an ECM from a truck very close to mine.  Only thing I could find was 2WD where mine is 4WD.  The other ECM did not change anything on my performance.
I purchased a Load Pro.  I am about to start load testing ground wires.  Maybe I will find the problem today.
22 minutes ago, Dieselfuture said:
Check your 5v loop, possibly oil sender shorted out.
  • 6 months later...
This is a really good thread for those of us with similar vehicular ailments, listing possible causes and diagnostic approaches.
Was there ever a resolution to this particular problem?
