- Replies 58
- Views 11.3k
BMC330 25 posts
Mopar1973Man 24 posts
Dieselfuture 4 posts
RipnRam99 3 posts
I could be wrong but, it sounds like you might have something going on with your 5-volt Loop, oil pressure sensor is on that Loop if it's shorts out internally it will create these similar problems. J
I would keep your pair of ECM and PCM. If the other donor truck is a matching truck with same options then I would take the ECM and PCM for spares.
You could just unplug it for a test drive. The gauge will not work but it'll prove the short idea.
I have a 2001 4x4 with a six speed transmission and 200000 miles. The truck is a one owner, I bought it from my Father in law and is completely stock. I have been around the truck since it was bought new.
The truck was really strong until around 190000 miles when the VP44 went out. The pump has been replaced with a unit from a local re builder in Memphis TN. Since the VP44 replacement the truck has not been the same. I drove it around 200 miles yesterday and it averaged 11MPG. I have owned 24 valve Dodge trucks in the past and have always gotten high teens on fuel mileage and had much more power.
When I am accelerating thru the gears I cant manage more than 5 pounds of boost until the truck gets up to 2100 rpm and it is like you flip a switch and the boost raises quickly to around 22 pounds. If I am cruising on the freeway around 70 MPH I have around 10 pounds of boost and the exhaust temp is around 900 degrees. I am unable to produce more than 5 pounds of boost under 1800 RPM.
The truck has never had any injector work done that I know of. The engine runs and starts perfect it just does not have any power. I cleared all the codes from the computer with a Matco scanner and drove the truck. I had a P0216 code re appear but I don't have any of the symptoms related to the VP44 going out unless the low power and fuel mileage are related as the engine runs perfect.
Any advice on where I should start looking to find my problem? Don't know if it has any bearing but I cant make the truck produce any black smoke. I know black smoke is not necessarily a good thing but all of my other trucks in the past have had black smoke.
I have made some up grades to the truck since I have been reading on this forum,
Gauges, Fuel Pressure, Boost Pressure and Exhaust Gas Temp.
Fuel Pump, Fass 95 GPH. I have 17 pounds of pressure while driving it down the road. The stock pump showed to have around 11 pounds at an idle and 7 pounds under wide open throttle.
I am not looking for a power monster only to get back to where the truck was before the VP44 replacement.
