Sucking air at hard pulls
- Replies 17
- Views 2.8k
Phantom5.901 8 posts
Me78569 4 posts
JAG1 3 posts
Dieselfuture 1 post
Popular Days
It's probably not sucking air it could be the issue some have with too much pressure in cylinders on high boost situation and letting off to fast causes pressure to be injected back through the inject
Just a thought...... try running with the fuel tank cap off you may have a bad tank vent.
I got a 2001 24v with 150hp injectors air dog150 with sump kit at wot 15 lbs quadzilla programmer and a year old hot rod pump the problem I’m having is when I get on my truck and let off slowly is dies and I gotta crack the lines to get it to fire up and body know why it’s doing this thanks
