Isspro EVA
Seeking reviews on the Isspro EVA mechanical gauges. Going to be receiving a tax refund this year so hopefully I can get me a set. I havnt noticed this line of gauges anywhere but DAP and theyre 3 times cheaper than the ev2s are they still good quality? Obviously the price difference is problably mechanical vs electric.
  • Replies 27
  • Views 7.2k
    Oh come on you wanted all the bells and whistles. Actually I wanted to find a way to hook up the relay to the check gage light and chime.   Crazy idea...
  • Marcus, I have the Isspro Mechanical EV1 gauges for 10 years on my truck    Isspro are excellent guages   They work great, Never had a problem at all . Fuel Pres. Trans Temp,
  • Dieselfuture
    Dieselfuture
    I put a 1/2" fuel line over 1/8" guage line, so in case it does leak it will be outside of cab, it pokes out an inch or so pass the firewall.I it's the blue line, also notice on air horn I used same f
I run EV1 gauges as well. I did have a leak once, but it was due to the compression fitting not the gauge. It was just a drip. I smelled it long before it made a puddle and just turned it off under the hood at the needle valve. I now run braided steel hose up to the gauge with -4an fittings on it. A smaller version of what all the other fuel line is run with so I highly doubt it will give me problems, especially not at >20psi. I did the boost in this as well.
Like others have said, the EV2s have bells and whistles. Its your preference. Mechanicals can be more of a pain to install. I do think the incandescent bulbs match the truck better.
Also, my EV1 FP has developed a bit of a buzz that kind comes and goes.
I drilled a small hole in the bottom of the pod with the fp gauge so i would know if it leaked and it did. Had to re tighten the line.
haha I did the same thing! I actually smell the fuel before it even found its way out the hole. It was just coating my gauge when I pulled it.
Old picture but here is my pod, it supposed to sit back buy windshield but I mounted it up closer. Much easier to see and run lines/wires.
