stop P0230 code in a Fuel boss only setup
- Replies 26
- Views 5.7k
s10010001 7 posts
IBMobile 6 posts
dripley 5 posts
Dieselfuture 4 posts
Just california.
Here's what I did with my fuel boss set up. Had my SMOG test run back in December with no codes and no problems. You can just run the wire from the ECM for the fuel pump to terminal 86 and ground t
I don't ever want to go to California it's ruined, Illinois is not far behind in its own way.
I run a fuel boss only setup, no check engine light but I get a P0130 (and its 1693 companion) code if I go looking. I need to get a smog check this week so I'm preparing for that. Is there anything I can jump, remove, connect that will make the computer think a electric pump is present?
Otherwise ill strap the old junk electric pump back in there and plug it in just long enough to get smog don't. .
