White smoke on start up less with warm motor
I have a 2002 2500 5.9 that when started on a cold morning blows white smoke for a min then stops. When I stop some Where and get back in and start up it puffs white for a second. No loss of power no CLE no soft codes. Not sure of fuel pressure. I know I need a gauge. My question is is this somwthin I need to worry about or no? I just started seeing it the last few days. But the temp has been colder the last few days.  Thanks for any and all help!
  • Replies 44
  • Views 6.6k
  • Unreal Summit
    Unreal Summit
    That's a good idea with the fuel pressure gauge. I need to just bite the bullet on it.
  • I don't know what additive you used but I would highly recommend using some 2 cycle oil. I use super tech from wall world. It is good for the entire fuel sytem especially the VP. Today's diesel is not
  • Here is an article about it. One oz per gallon is the desired mix but dont worry if you put to much or dont have enough at a fill up. Any is better than none. Just try and keep it close. TCW3 is
Alright thanks y'all! I am going to keep an eye on things and see if it smokes again anytime soon.   Bout a quart per tank sound right for the 2 stroke oil?  I appreciate all of the help!
Since you’ve haven’t added before just wait until your next full tank and then depending on how many gallons your tank is, add that many ounces. Then every fill up after that add 1oz per 1g.
One oz per gallon is the desired mix but dont worry if you put to much or dont have enough at a fill up. Any is better than none. Just try and keep it close. TCW3 is a must as mentioned mention above by @notlimah. It is ashless.
Edited by dripley
I'll have my wife get me some on her way home.  Thank you so much!   Hopefully my white smoke wasn't anything to worry with and I can get a fuel pressure gauge asap
It is cheaper by the gallon if you dont mind measuring your self.
 Terrible pic but where the muffler ends it's rusted off and then u see the smoke. Like this till the grid heater stopped cycling. Normal?
187,000  stock injectors as far as I know.  So I take it the blue haze ain't normal for cold start then?
What’s the temperature when cold starting? As far as I know when it’s cold your going to get blue smoke. I get blue smoke when it’s 15 20 degrees and I have brand new injectors.
Injectors are most likely shot. Typically have to replace 100-150k miles.
Typically the blue haze could be either fuel that is not burning or like in my case it valve guide seal that are failing. But valve guide only let off a single puff of blue smoke and it smells like burning oil. Since you not talking about a burning oil smell I would have to stick to the injectors are worn out.
It was 32 with strong winds this mornin unknown wind chill.   Is it safe to drive or do I need to stop and get new injectors asap
You can drive it but you might get stranded when they go out somewhere away from home but if you drive the truck around local I’d go for it.
Safe to drive but the file economy will be lowered.
In a nutshell how these engines work is your compressing air enough to create the heat. Then injecting fine atomized fuel into the heated air to make it go bang. So when the injectors wear out the injector pop pressure opens early. So stock is suppose to be at 4,500 PSI +/- 250 PSI. Now the injector is opening early the spray is not atomized good so there is a smoky haze because the heat isn't enough to make all the fuel burn completely.
The most you might notice is a offbeat or miss idle when hot this is the injectors causing this.
Alight thanks guys. I guess I'll try and baby it around town and work some ot and buy me a set. Rv275s is what y'll would recommend for good fuel mpg and reliability?
