- Replies 19
- Views 3.4k
mrclean 5 posts
GSP7 5 posts
dripley 4 posts
Mopar1973Man 3 posts
Popular Days
These truck aren't bad. I look at mine with 15 years of age and 338k miles on the clock and still got all the electronics working just fine. It, when people ignore warning signs like the torque conver
What is your WTS light doing? On at key on or delayec?
You ought to see it at key on no matter what. It will come on briefly no matter what the temp is.
Truck in my sig......
This truck has had a FASS 150 on it for @10 years, has and still does work correctly. Up until yesterday, key "on", pump ran a couple of seconds, or bump the starter and pump ran for @20 seconds. Yesterday, key "on", no pump, bump the starter, pump runs a few seconds and shuts off. The FASS is run with a relay plugged into the factory lift pump harness. The truck starts and runs, and maintains @14 psi constant after being started. I unplugged the FASS harness, tested the relay and the harness, checked out ok, and the pump runs with 12v direct to it. Key "on", the factory lift pump harness shows 7v, bump the starter it goes to 9v-10v for a few seconds, then back to 7v ( I neglected to check voltage there with the engine running). The factory pump harness appears to be intact. The CEL is not on, though my scanner picked up a companion code P1693, but it didn't specify what the problem is. Also, I cannot clear this code. Any ideas on what has failed?
Edited by mrclean
