1/4 tank limp mode?
Hey guys on my 99 24V when ever my tank gets to 1/4 tank my truck goes into a lim mode, truck will still tell me I have X amount of miles until empty. Won’t leave 1st gear or exceed 20MPH. I think it’s something todo with the sending unit but really not sure any help is greatly appreciated
  • Replies 13
  • Views 3.3k
  • The only thing the transmission and fuel sender/gauge have in common is the PCM.
Have you checked for codes when it happens? It does seem strange.
I haven’t gotten an engine code since I’ve owned the truck. It does it every time I hit 1/4 tank
I don’t think so, 34 gallon tank and only takes 24 to fill it up.
I have to assume the problem goes away after you fill it up?
Yes fill it up and truck runs good again shifts fine and runs like it should
Do u have a draw straw? Also is it running like crap or idles revs normal
Edited by Silverdodge
Yes but had this issue before the draw straw was installed
Fires up fine, idles fine and drives up to 15-20 mph then won’t leave 1st gear
I've seen one case where a transmission shop installed a voltage regulator for the transmission wrong. Instead of tapping the power wire they cut it to the PCM which caused all kinds of weird issues. I know modified transmission typically have either a resistor or a voltage regulator install for the governor pressure sensor.
