- Replies 11
- Views 4.6k
Mopar1973Man 6 posts
notlimah 3 posts
Dieselfuture 1 post
Quadzilla Power 1 post
Ok here is the difference between the 10 year old plate and the new plate. The new plate has a nut to back up the jam nut on top. That was an issue with my old plate if I was to over tighten the jam n
With the HX35/40 Hybrid and the +75HP I'm able to light the tires up in 4th gear again. When the wiretap hits the boost snaps to 45 PSI and the tires just break loose. I got a good scratch going in t
No. It doesn't matter. If the wire isn't hooked up the setting are meaningless. I only used level 3. Level 0 = Stock. ECM only, display data only. Level 1 = Valet Mode Level 2 =
My warranty should be over or nearly over for my VP44. Time to return back to wire tap tuning again.
There is a reason why I'm not re-using my old Stealth Plate. I'll show you the difference in my next post. I bought my first Stealth Plate back in 2007 that is 10 years ago and several updates have been done to the old original plate I bought 10 years ago.
