Relationship between fuel pressure and boost
- Replies 8
- Views 2.6k
Mopar1973Man 2 posts
notlimah 2 posts
portlandareae28 2 posts
jlbayes 1 post
Popular Days
Realistically the vp will continue to produce power as long as it has positive inlet pressure. The internal vane pumps kicks arse. Now that being said I would not want inlet pressure that low as every
Is there a relationship between fuel pressure and boost? My truck idles at 17psi, but will dip to 8-9 on a hard run. Is this having an effect on boost numbers? I only seem to get to 15-18 stock and even with the edge on (comp not currently tapped) pretty rare that it touches 20psi. Boost elbow or plugged manifold don,t seem to change anything.
