Previous issues and a new noise.
- Replies 22
- Views 5.4k
Marcus2000monster 10 posts
Mopar1973Man 6 posts
trreed 3 posts
SilverMoose 2 posts
Why not check before rebuilding? That could be the whole issue.
Not typically. Basically the P0122 or P0123 is when the APPS sensor goes out of range either hi or lo voltage. When it does the ECM normally dead pedals for protection so not to either be in WOT or so
I believe this is related to my low power and P0237 issues but last evening I went and picked up a new boat 20 miles away. Idk when it started but i started hearing a lot of what sounds like valve chatter. Something tells me it has nothing to do with the valves but that it’s related to a timing issue. I’m also having rough idle symptoms again although a bit different from when I had air in fuel. What I’m thinking is since I have turbo play and all that i may have low boost which flipped the code and is causing low power. I also read somewhere here that low boost will create more timing and make a knocking noise and higher boost will retard timing.
This boat I bought is a 16foot aluminum boat. It don’t weigh much at all but o the way home going up a 5% grade the truck was very sluggish and I kept loosing speed in 6th gear going 65 up the hill. Also the turbo instead of making a whistle when I stabbed the throttle going up the hill it made more of a lower pitched whine. Any one else think my issues are related to the turbo?
Also would a boost leak tester provide the results needed to condemn the turbo?
