- Replies 12
- Views 3.4k
Ekillionc9 3 posts
trreed 3 posts
dripley 2 posts
Dieselfuture 2 posts
Popular Days
Parts for a 5600 aren't readily available because they're not supported anymore. Tools are insanely expensive, and iirc you need something like a 150 ton press to get gears off the main shaft. I'm not
There are several sources for rebuilt NV5600 and people will work on them. The results are not always good. There are also a lot of cheap parts on the market that won't last. They only made these tra
This is why parts are hard to get ahold of. As for the NV4500 was use a lot longer and used by both Chevy and Dodge. Which means there are more aftermarket
So I took off with a little extra spirit today and second gear decided to check out. Does anybody have and parts or have a good source to get whatever parts I may need when I open this can of worms? Also one more thing would help greatly is how much does this trans and transfer case weigh separately?
