- Replies 72
- Views 13.9k
Marcus2000monster 27 posts
Mopar1973Man 14 posts
dripley 12 posts
Ben 5 posts
Most likely never see the smoke. Some pressure and spray bottle full of soap water mix works just fine.
I mean, if there’s oil in/around your turbo and I’d at least clean it and see if it comes back. How else you going to know where it came from?! Lol
Yes, your turbo is an HX35 @GSP7. Genuine Holset kits can be found at DAP for around $60. Check if you have oil in the intake side. That's a sign you need seals. And any linear movement of the shaft
Anyone here rebuilt there hx35? I guess I’m going to attempt it myself tomorrow. Any tips or suggestions? Hope I don’t mess anything up. I plan to check for boost leaks before I rebuild it. Anyone have a diy tester they have built?
