Went Loggin'
Was coming home from dog training last week. We got done right at sunset. So I'm driving home in the "sorta" dark. You know, that time between sunset and dark where your headlights ain't doing squat!!! Anyhow, on the ride home, it rolled over a "log" in the road!!! It made an terrible racket under the truck, but I didn't think anything more of it until I turned into my drive. EEEEEEEERRRRREEEE!!!!! Bent the snot out of the steering stabilizer!!! Nothing else as far as I can tell!! I tried to take some pix, but none of them were good enough to post to show the bend in the shaft and the kink in the tube of the stabilizer!!!:smart: I must've took 12 pix and all of them sucked!!! Sorry guys!!:banghead::banghead:
  • Replies 21
  • Views 7.7k
That sucks, hopefully thats all you damaged..Upgrade time :-)
That sucks, hopefully thats all you damaged.. Upgrade time :-)
Already changed her out. 20 minute job.........non-union!!!:lmao2::lmao2:
are you talking about one of these? http://www.vulcanperformance.com/PSC-Steering-Box-Stabilizer-for-94-02-4WD-p/pscss.htm i am about to put one on. you don't think that could bend the pitman shaft?
No, I'm talking about the shock looking thing that attaches the steering arm to the axle. You've linked a "steering box support/stabilizer". I've got the BD version of that on my truck!!
Was trying to find a pic for guesswho and found this instead.
Guesswho, he bent the shock behind the skid plate, that shock works the same as the ones on the suspension, resisting fast movement to allow for better steering control, or "stabilizing" it. One end connects to the axle to have something solid to work with, and you can see the other end connected to the track rod to stabilize it. So when you hit that raccoon on the road, it should stay straight, how it's supposed to work anyways :lol:
Think that skid plate would have helped you dorkweed :thumb1:
Posted Image
Thats not a diesel :-)I have thought of running one of those skid's on my truck thou.. not sure how sturdy they really are.
oic, i think skid plates are in my future, just got to find everything's order:banghead:(quadzilla,frontend work, pillar gauges,?vp44?,skidplates,spray-in bedliner):evilgrin:
Yeah, but no skid plate there on my truck!!!:cool:
Its too bad they only put them on the power wagons! They would be useful on all 4wds.. But heck my 4wd didn't even come with a xcase skid, had to add that myself.
  • 4 weeks later...
dang sure would like to find one of those skid plates for my truck
:iagree::iagree::iagree:need some skids myself... i'm almost afraid to hit the hunting lease in fear my open airdog!
Huh? Mine is tuck behind the transfer case and protected by a skid plate???
Posted Image
But thats not the OE mount is it?
If I ever do a filtered pump I plan to put it in a similar fashion, up and out of the way!
On a side note, have you seen the new f/w sep AD is using? Really improves the separation. Luberfiner LFF9594.
Yes it is... Short box edition...
No... :shrug:
Oh wow, not bad. Most the mounts I have seen hang the filters below the frame.
No... :shrug:
Based on someone, :whistle:, posting the specs on their filters, they decided to upgrade to a filter that is as close as possible to stock filtration.
Old filter, 20 GPH 50% free water sep, 0% emulsified
New, 90 GPH 95% free water sep, 75% emulsified. (Luberfiner LFF9594)
On a note, don't use any Fleetguard crosses for the Luberfiner, they are rated at 20GPH. Not sure on Donaldson.
this is for the 100 and 150?
Yes, and the new ADII as well.
Thanks again for the info on the fuel filters AH64! I am looking a supplier for the LFF-9594 that will sell just 1 or 2. So far I have found one that will sell a case of 12. I would be willing to start a group buy if anyone is interested. Chris
I have the pillar and wish I had gone with the dash mounting. The dash is a lot easer to watch driving. They set in frunt of you so you don't take your eyes off the road like the piller mount.
