- Replies 19
- Views 7.9k
Mopar1973Man 5 posts
Youngblood24v 5 posts
notlimah 4 posts
rogerash0 3 posts
https://goerend.com/goerend-47-48re-transmission-pan-kit/ No complaints about my goerend
Yea man, those numbers are nothin to shake a stick at. If it were over 190 constantly then yea you’d have cooling issues. Seeing a 20* shift is proof that your port isn’t getting adequate fluid to mea
I did the 15960 and made an alum bracket with drill bits/drill, bolts, grinder and a long stick of thick aluminum 90* angle stock from home Depot. Just made it first with cardboard and tape. Mounted i
Getting an aux trans cooler for my truck pretty soon here. I’m also getting a deep trans pan. I’ve narrowed it down to the Derale 15840 and the 15960. Anyone have person experience with any of these? Or if you have another suggestions fire them my way! I’m also going to do the Derale electric fan set up adventually when I get time. Also is their any good write ups on installing these on our trucks? I did a quick google search and didn’t come up with much
