AC clutch
Recharged the ac last week got everything up and running fine. On the way home the air went from 40* to 80*. Made a pit stop got back in fired her up and she worked for about an hour or so then back to 80*. Upon further inspection I see that the clutch is turning very slowly and a little jerky like the clutch is fried. What can I check to see if thats the case or just maybe the pressure switch.
  • Replies 37
  • Views 16.3k
    I've given up, on the whole, trying to keep factory or Cummins only parts typically this turns out to be the most expensive solution and doesn't promise that it will give the same lifespan as the repl
  • IBMobile
    IBMobile
    What has happened is the air gap between the clutch plate and the pulley has increased due to wear.  The air gap is large enough now were the electromagnet can no longer keep the clutch engaged to the
  • IBMobile
    IBMobile
    You can double up the gauges to check a bigger gap,  .026+.014= .040"     I've pulled clutches and removed shims to adjust the gap on other compressors but I've never done one on these truck
6 minutes ago, dripley said:
Mine spins very slowly when it does it. I wont be long before it stops completely like yours. If I could get to it easily with out removing it from the truck I would adjust the clutch for now. But it looks like I would to take it off to adjust the gap. If I am that far into it I figure to just replace it all.
I got a buddy up in Wisconsin who's selling me his for $50 since he doesn't need it on his #racetrok
Be sure read @IBMobile article and posts above. You will have the system wide when swapping them. Makes a bigger job out of it but worth it.
@IBMobile could I get away safely with just obviously getting a new compressor and maybe an orface tube? I have a vacuum and gauges already and I really don't wanna redo the whole system so I can save money for some upgrades.
Here is everything including a new compressor for less the $200.
https://www.rockauto.com/en/moreinfo.php?pk=3934884&cc=1440064&jsn=451&jsn=451&jsn=451
I am leaning towards this one more so than the first. Costs a little more plus you would need the o rings and seals. they have them also and still think you are under 2 bills. Shipping is another 25 bucks.
https://www.rockauto.com/en/moreinfo.php?pk=5245524&cc=1440064&jsn=455
And if you go for the used compressor i think the other parts are less than $50.
Just got done driving my truck and the clutch has completed quit now, takes a bit to even feel cold air. Around 5-10 minutes
Mine dropped to 40 or so this am but when turning slowly only about 80.
i have to replace the whole compressor as when i rebuilt the engine something happened to the coil that actuates the clutch. its dead shorted somewhere and it wont work at all even hooked directly to battery (burns wires...)  so yeah new compressor for me...
All the parts you need are not that much more like @dripley said and it's cheaper and more time efficient  to do it right the first time.
On ‎5‎/‎12‎/‎2018 at 6:45 PM, dripley said:
Guess I am headed in the right direction then. Lot of unkowns in whats available. OE is $500 down to kits for $155. Not finding alot of reliable info on the lessor ones. Anyone have any experience with the after market ones?
One year ago I purchased a Denso compressor (same as OEM ) from Amazon for $203.00 with free shipping.  The original compressor was still working fine at 270,000 miles, but the shaft seal was leaking refrigerant, so I was having to recharge frequently.  Since the first compressor, a Denso, was so reliable, I went with another new one.
- John
- John
Rock Auto has a Denso too. A lot cheaper, $123,  than the one you got, no telling where any of them are made from the research I did. Makes choosing fun. I do appreciate the input.
I understand - good luck with your search.
- John
Well I have been looking since I started this thread and have come to the conclusion that there is no straight answers to what you will get when ordering a new. I went to Denso and their recommended suppliers cover a wide price range. Rock Auto $125 to AA and AZ at $300+ for the same part #. Sanden with similar results. Makes me wonder where the Mopar places are getting theirs at $500 or so. Even the drier on RA is over a $110. So I am going to close my eyes and roll the dice.
Just using the Denso part number NAPA what's over $300 for theirs. Same part # at RA $125. Do you remember which one you used?
Whatever was cheapest at the time... :shrug:
That's a good answer. Appears I will be taking the same course of action.
I've given up, on the whole, trying to keep factory or Cummins only parts typically this turns out to be the most expensive solution and doesn't promise that it will give the same lifespan as the replacement. Kind of like @Me78569 doing Spicer ball joint to resolve a ball joint issue and they didn't last. Kind of like most chase the brand name Moog ball joints and don't last. I just picked up the cheapest ball joints AC Delco and still going. Chasing brand names for quality doesn't mean you'll get it.
