- Replies 5
- Views 6k
Mopar1973Man 1 post
Dieselfuture 1 post
quoris 1 post
trreed 1 post
Popular Days
Well there’s a lot going on here so I’ll address part. Without getting into a debate, the 47re can be built to handle what you’re talking about no problem. Will that last for 200k not sure
Allison isn't the end-all be-all that everyone thinks it is. A well built 47RE will be more than enough for your goals. You will be pushing a stock Allison pretty close to its max for what you want t
Well I got a 01 3500 stock auto slush box. stock hy turbo. stock, stock, stock. Easier to talk about the few upgrades I do have. Airdog 150, BHAF, Old programmer/tuner from like 2002. I am at cross roads as to what to do next. one is how to build the engine. The other is what tranny to put in it. My goals are to have a tow monster and power to have fun with. I don't mind slow turbo spool up speed but i do want one hell of a loud turbo whistle from the intake. I want compound turbos and I know a single turbo might be an option but am thinking it can't do it. I am able to fab up the mandrel bent pipe for the intake. I am not opposed to buying a bolt on kit just need to weigh my options. I will do studs and maybe upgrade the intake springs to run higher boost to get more whistle if it would be worth it. Not sure what combo of turbos to get, or what injectors to put in it. The tranny will be a 47re of course or adding two extra gears to it with an Allison. A bolt on Allison is 12k down to 5k. The transmission is the toughest decision to make. I know the 47re can do it but will it hold up for 200,000 miles like the Allison will all stock. Almost forgot i need an exhaust brake on this setup as well. As far as HP numbers go i don't know. The Airdog might be my limiting factor on that. Just trying to weigh all the options I have for the setup I want.
Forgot to mention 4x4 and 4 inch exhaust
