- Replies 25
- Views 5k
dripley 6 posts
Dieselfuture 6 posts
Mopar1973Man 5 posts
CTcummins24V 4 posts
Well I hate to say this but I have never completely changed or flushed my PS fluid. I have on several occasions taken the "turkey baster" thing and sucked what fluid I could get out of it and replaced
It shouldn't mater. They are both return lines to the reservoir part of the pump.
I have 442k on my oe pump and keep waiting for it to explode. It is a touch weak and shows that at idle every so often. Probably ought to just replace. I believe I got my moneys worth out of it.
Hopefully replacing my power steering pump tomorrow. There is a threaded pressure line at the bottom of the pump and then I think 2 return lines to the pump from the booster and gearbox. If they are both return lines, does it matter which stub the hoses are attached to on the pump? I was reading IBMobiles filter article and I may have my return lines crossed, but in theory it shouldn't matter. I also have a filter on the line coming from the booster to the pump where IBMobile has it on the line from the gearbox?
