- Replies 23
- Views 8.3k
dripley 5 posts
GSP7 5 posts
Mopar1973Man 4 posts
oldsilver 4 posts
Popular Days
I am a bit surprised they would tell anyone to wire a fuel pump to key on hot knowing what might happen in a wreck. I know alot of folks have done it but would not think a company would recommend it.
I'd never use any kind of quick connector or 3/8" lines. I would upgrade to full 1/2" lines from the tank to the VP44 using Parker Push Lock fittings.
First off with a mechanical gauge you won’t see pressure after you shut it off. You should see a quick blip of pressure at key on, then like Mike mentioned the 7-12 psi while cranking. Sou
I just installed a Fass 165gph system on my truck. I previously was running the carter pump on the frame with no issues. Now if I let my truck sit over night it cranks longer before it starts. Also I see no fuel pressure on my gauge until after the engine starts. My fuel pump is wired to the 10 amp fuse in the cab marked ignition. After the truck sits over night I turn on the key and check the fuel neck to see if the pump is pumping and maybe my gauge is wrong but its not until the truck starts. I am lost on this one its not that complicated of a system but this has me stumped.
