- Replies 22
- Views 7k
903Dodge 10 posts
Quadzilla Power 5 posts
Mopar1973Man 4 posts
Me78569 2 posts
Have you checked your alternator for AC noise? That can cause all sorts of gremlins in the system.
Might try look at both...
Simple... Unhook the Quadzilla. Now turn your key on reset all codes. Double check your all cleared. Now fire up go for a good 10-15 mile test drive. Check the codes again. I
I am on the road today haven’t had a chance to stop and check but my quad is showing 48psi at idle and the quad stays in power level 0
Beside a wire could my MAP sensor be dead?
When I get home I will look under the hood.
