- Replies 36
- Views 11.1k
notlimah 17 posts
Me78569 10 posts
Mopar1973Man 6 posts
Dieselfuture 2 posts
I agree with mike. Watch OEM then fill the hole
That's pretty normal for those size injectors.
Yea man, I’ll try it out on the way home tomorrow, I’ll try and grab some video if I can too.
Installing some new injectors and wanted to double check some timing values with you guys.
Setup is in the title, current timing values for the tune I’ll use are...
max load timing offset - 2*
low psi timing reduct - 5*
timing reduct scaling - 50%
light throttle timing adv - 2*
light throttle load limit - 30%
