Algae in Fuel
Just changed my fuel filter, it was black, can't remember the last time I changed it. Fuel pressure was dropping with acceleration and boost wouldn't go much above 25psi, which it shouldn't with the fuel boss. Black granulars in the stock filter housing. Truck sits all winter and doesn't get used a whole lot in the summer, so I'm guessing there's algae. Anyone experience this? What's the best product to run? Bio Kleen? I'm going to change the filter again in a week or so and see what it looks like.
Edited by CTcummins24V
  • Replies 30
  • Views 7.1k
  • I have had algae in a couple of tractors on the farm, used bio kleen or whatever power service calls theirs. When I had it in the tractors it looked like black snot in the fuel filters, I got a bunch
  • CTcummins24V
    CTcummins24V
    Thank you @01cummins4ever!!! I took the bypass check valve off, no visible debris. Used a pick to compress the spring multiple times, blasted it with brake clean from both sides, compressed the spring
Thank you @01cummins4ever!!! I took the bypass check valve off, no visible debris. Used a pick to compress the spring multiple times, blasted it with brake clean from both sides, compressed the spring a bunch more. No matter what she stayed between 15-18psi the whole drive! That valve clogging didn't even cross my mind. It all makes sense now. My fuel was pretty clean, just a nasty fuel filter with debris in the housing.
Definitely installing that strainer pre fuel boss and bypass valve this weekend.
Right, It's a 24 micron stainless steel mesh fuel strainer used pre-pump.  It is not a fuel filter.  I think I'll get one for my Fuel Boss system.
@IBMobile, off topic, but what can you peg your boost to and what are your normal boost numbers cruising and towing? We have similar set ups, unloaded I can't hold sustain than 15psi and having trouble getting much over 30psi accelerating, with the comp in EZ mode.
The only way to sustain 15 psi of boost is under accelaration tuner or no tuner. Cruising will see minimal boost since fuel demand is low. Mine cruises 75 mph at maybe 3 to4 pounds with the tuner on or off. You just don't have enough fuel to produce much boost cruising. I don't know enough about your turbo to know what the max boost on it should be.
 Hope I did not butt in on your question.
@CTcummins24V I run my edge on level 2 and @dripley is right about the boost.  If it's towing or not the best boost I see is 30psi, that's what I set the boost controller at and I don't think my HX turbo would produce much more than that.  I normally drive 65-70 and  tow at  60-65 mph, the boost is 0-5 psi when cruising.
I was just curious. I took off the super b and sold it. The holset is much better down low but seems to choke out around 30psi and higher rpms. Super b had bad low end but incredible mid range and ok top end. Truck is running great and clean with the holset and pulls strong up to 25psi while 30psi and above isn’t pushing any extra power.
