- Replies 45
- Views 7.5k
TheGreatWhite 18 posts
Mopar1973Man 9 posts
Ed ke6bnl 4 posts
Dieselfuture 4 posts
Another test is to unplug the low-pressure sensor on the accumulator and use a paper clip and bridge the contacts. Typically that starts the compressor. It could be a bad high-pressure switch by the c
Let's start with the A/C relay. Pull it out and jump across the 87 and 30 pins. Double check the Fuse J (10 Amp fuse) in the PDC. If it starts we know that circuit is working.
Something I caught him on was the used compressor he bought had spilled out all it oil. So I'm glad it didn't fire up because it would of been a for sure black death. Then I was working at the clutch
Finally got around to redoing my A/C after sweating my butt off for a month. Replaced the Accumulator, Orface tube, and bought a clutched that worked from a buddy of mine, added refrigerant to it and the clutch isnt engaging when I turn on Max A/C and everything. My gauge is reading about 120 and according to my phone its about 82* right now. Anything helps, thanks!!
Edit: I forgot to mention the 120psi is on the low side and yes I did evacuate the system for 45min.
Edited by TheGreatWhite
