- Replies 18
- Views 3.1k
Brianh 7 posts
Mopar1973Man 6 posts
015point9 3 posts
Royal Squire 1 post
After installing the RV 275 injectors and quad xzt, I used a turnbuckle on my hy35 to get more boost, (it will be replaced with an hx35 soon)) with that I can get 30 psi of boost but my egt will go th
My gauges in "A" pillar pod mount. My fuel pressure light used to come at 5 psi. Not good and got me in $$$ trouble. Now comes on when below 15 psi. I changed pressure switch. Mine is 24 va
I know that you guys have said that the HX35W is the turbo to get, but my HY35 has worked well for 250K. I currently have 100HP injectors, 5" exhaust, Air Dog, HBAF, and low fuel pressure light. I do not have an EGT sensor or tuner, and tow a camper and bass boat, so I am slightly worried about my EGT's, but figured the 5" exhaust would help keep those in check. SO, do I rebuild the HY35, or spend the big bucks to get a HX35W, as I can't seem to find them used with low miles.
Oh the current HY35 has oil leaking on the intake side, so I am pretty sure it is toast.
Thanks
